Network Management
Airwave 8.2.4 backup aruba/hp switch configuration
  • 1.  Airwave 8.2.4 backup aruba/hp switch configuration
    Posted Jun 25, 2017 08:24 AM
    Im trying to backup my procurve switch configs into airwave. I created 2 folders. 1 folder with a 2930 switch and 1 folder with a 2520 switch.
    When i run the audit i can only see this output:
    Device Settings
    		Current Device Configuration
    	Name 	2520G-8-PoE-NEW
    	Serial Number 	XXXXX
    	Specific Model 	2520G-8-PoE
    	Uptime 	85 days 21 hrs 40 mins
    System Properties Current Device Configuration Contact contactone Description HP J9298A Switch 2520G-8-PoE, revision J.15.09.0027, ROM J.14.05 (/ws/swbuildm/J_rel_hartford_qaoff/code/build/walle(J_rel_hartford_qaoff)) (Formerly ProCurve) Location XXX ObjectID .1.3.6.1.4.1.11.2.3.7.11.96
    When i look at the executed commands i see this:
    Sun Jun 25 13:02:01 2017:
    >> no page
    >> configure
    >> console local-terminal none
    << sequences removed from the output. To exit this mode, use the
    << command "console local-terminal vt100".
    >> session interactive-mode disable
    << Invalid input: session
    >> terminal width 1920
    Sun Jun 25 13:02:02 2017:
    >> include-credentials
    <<                               **** CAUTION ****
    <<  This will insert possibly sensitive information in switch configuration files,
    <<  and as a part of some CLI commands output. It is strongly recommended that you
    <<  use SFTP rather than TFTP for transfer of the configuration over the network,
    <<  and that you use the web configuration interface only with SSL enabled.
    <<  Erasing configurations with 'include-credentials' enabled will erase stored
    <<  passwords and security credentials.  The system will reboot with the factory
    <<  default configuration.
    <<  Stacking and 'include-credentials' are both configured on this switch.
    <<  'include-credentials' must be enabled on all other switches which are
    <<  a part of this stack, otherwise stacking passwords will not be propagated
    <<  properly.
    >> exit
    >> logout
    In the AMP settings the number of backups to keep is 10.
    I can see all the ports in airwave and i doublechecked the credentials and SNMP settings. This all looks good and i even can run commands.
    I also tryed to create a backup job with manual time. also here here is no success.
    log:
    Sun Jun 25 14:07:29 2017 	System 	Device 	Aruba 2915-8G-PoE HP-2915-8G-NEW Configuration verification succeeded; configuration is good 	2 	Top 	switch2
    Sun Jun 25 14:07:16 2017 	admin 	Device 	Aruba 2915-8G-PoE HP-2915-8G-NEW: Updated 	2 	Top 	switch2
    Sun Jun 25 14:07:16 2017 	admin 	Group 	switch2: Updated
    Sun Jun 25 14:03:13 2017 	System 	Device 	Aruba 2915-8G-PoE HP-2915-8G-NEW Poll now complete 	2 	Top 	switch2
    Sun Jun 25 14:03:11 2017 	admin 	Device 	Aruba 2915-8G-PoE HP-2915-8G-NEW Polling now 	2 	Top 	switch2
    Sun Jun 25 14:01:29 2017 	System 	Device 	Aruba 2915-8G-PoE HP-2915-8G-NEW Configuration verification succeeded; configuration is good 	2 	Top 	switch2
    Sun Jun 25 13:57:14 2017 	System 	Device 	Aruba 2520G-8-PoE 2520G-8-PoE-NEW Configuration verification succeeded; configuration is good 	1 	Top 	Switches
    Sun Jun 25 13:57:04 2017 	admin 	Device 	Aruba 2520G-8-PoE 2520G-8-PoE-NEW: Updated 	1 	Top 	Switches
    Sun Jun 25 13:56:04 2017 	System 	Device 	Aruba 2520G-8-PoE 2520G-8-PoE-NEW Poll now complete 	1 	Top 	Switches
    Sun Jun 25 13:55:47 2017 	admin 	Device 	Aruba 2520G-8-PoE 2520G-8-PoE-NEW Polling now 	1 	Top 	Switches
    Sun Jun 25 13:54:29 2017 	System 	Device 	Aruba 2520G-8-PoE 2520G-8-PoE-NEW Configuration verification succeeded; configuration is good 	1 	Top 	Switches
    Sun Jun 25 13:44:28 2017 	System 	Device 	Aruba 2520G-8-PoE 2520G-8-PoE-NEW Configuration verification succeeded; configuration is good 	1 	Top 	Switches
    Sun Jun 25 13:43:29 2017 	System 	Device 	Aruba 2520G-8-PoE 2520G-8-PoE-NEW Configuration verification succeeded; configuration is good 	1 	Top 	Switches
    Sun Jun 25 13:42:29 2017 	System 	Device 	Aruba 2520G-8-PoE 2520G-8-PoE-NEW Configuration verification succeeded; configuration is good 	1 	Top 	Switches
    Sun Jun 25 13:33:47 2017 	System 	Device 	Aruba 2520G-8-PoE 2520G-8-PoE-NEW Maintenance window "Backup test" ending. 	1 	Top 	Switches
    Sun Jun 25 13:23:46 2017 	System 	Device 	Aruba 2520G-8-PoE 2520G-8-PoE-NEW Maintenance window "Backup test" starting. 	1 	Top 	Switches
    Sun Jun 25 13:22:45 2017 	admin 	Device 	Aruba 2520G-8-PoE 2520G-8-PoE-NEW: Updated
    Did i miss something? thanks!
  • 2.  RE: Airwave 8.2.4 backup aruba/hp switch configuration
    Posted Jun 26, 2017 04:59 AM
    May I know model/firmware version of switch.Does configuration status is showing as Good for switch in APs/Device>monitor page?
    Does credentials which you have configured have full rights to execute the commands?
    In Switch's APs/Devcies>Audit page , we see configuration backup details.
    In telnet/audit log, I see you have stacked the switch, as per this message it says to enable include-credentials on all the switches which are part of stacking.
    Have you enabled this option on all stack switches?
    <<  properly. I
    Pavan
    If my post addresses your query give kudos:)
  • 3.  RE: Airwave 8.2.4 backup aruba/hp switch configuration
    Posted Jun 29, 2017 05:24 AM
    It looks like its a firmware issue...On the old switch i cant get it to work. On the 2930 its no problem.
  • 4.  RE: Airwave 8.2.4 backup aruba/hp switch configuration
    Posted Jun 29, 2018 05:03 PM
    Hello, I'm new to AirWave and getting ready to work on setting up backups for an Aruba stack and some Cisco switches. Did you find any useful step by step in how and where to go to do this? I honestly don't know where to start in the AMP system and I don't see good documentation regarding this.
    Carl
