Network Management
Airwave 8.2.4 / configuration audit / "import button" is missing
  • 1.  Airwave 8.2.4 / configuration audit / "import button" is missing
    Posted Sep 30, 2017 04:41 AM
    Hello Airheads,
    I am wondering how to import a golden configuration into airwave to have a template for auditing.
    I have an Aruba 7005 controller running 8.1.0.2, which has been discovery successfully. I put the controller in a new group "WLAN" and auditing is enabled:
    Group settings of device group WLANGroup settings of device group WLAN
    In the section "APs/Devices" | Audit | Ican create a backup and see the latest running configuration. But I am missing the "Audit" and "Import" button to start auditing:
    Audit setting of Aruba 7005 controllerAudit setting of Aruba 7005 controller
    Auditing for Aruba Switches is working fine for me. Is there any global setting or what is going wrong?
    Best Regards,
    Michael
  • 2.  RE: Airwave 8.2.4 / configuration audit / "import button" is missing
    Posted Oct 03, 2017 12:01 PM
    Click on the Manage page and at the bottom right there should be an import button
  • 3.  RE: Airwave 8.2.4 / configuration audit / "import button" is missing
    Posted Oct 03, 2017 02:16 PM
    Hello Pasquale,
    thanks for the answer. My view doesn't have a Import button:
    I wondering if this a bug in the software or I missed anything.
    Best Regards,
    Michael
  • 4.  RE: Airwave 8.2.4 / configuration audit / "import button" is missing
    Posted Oct 03, 2017 02:48 PM
    Can you send a screenshot?
  • 5.  RE: Airwave 8.2.4 / configuration audit / "import button" is missing
    Posted Oct 03, 2017 02:54 PM
    Hello Pasquale,
    sure - here is the complete manage screen of the 7005 controller:
    here is the related group config:
    Best Regards,
    Michael
  • 6.  RE: Airwave 8.2.4 / configuration audit / "import button" is missing
    Posted Oct 12, 2017 10:29 AM
    Config support is not available for 8.x controller, hence  import settings and config audit as well as template based config wont be available.
