Network Management
Airwave 8.2.4 unapplied changes but "There are no changes to be applied"
  • 1.  Airwave 8.2.4 unapplied changes but "There are no changes to be applied"
    Posted Aug 18, 2017 01:51 AM
    I am running airwave 8.2.4 to manage a 7210 controller pair. I now ran into the situation that there is a mismatch shown on airwave: a aaa profile has a dot1x-default-role of authenticated but airwave thinks it should be guest. The controller configuration with "authenticated" is correct.
    I can't seem to get this fixed.
    I have changed the configuration in airwave to "authenticated". Save. I get notified I have unapplied changes. I press "Save and Apply". However, on the "Confirm Changes" page shown then there is only "There are no changes to be applied" and the cancel button.
    I have tried to repair the mismatch first, then make the change. Same result.
    I have imported the configuration from the controller, then tried to change it.
    So basically, whatever I could think of to make this change in airwave seems not possible. If I set it the role to "guest" in airwave there is no unapplied change to be applied. If I set it to any role other then "guest" I have unapplied changes but then are told there is nothing to be applied.
    I do I get this working again?
  • 2.  RE: Airwave 8.2.4 unapplied changes but "There are no changes to be applied"
    Posted Aug 18, 2017 02:28 AM
    I have noticed the same problem at one of the virtual ap configurations in airwave for those controllers. But for that part there are unapplied changes of another user.
  • 3.  RE: Airwave 8.2.4 unapplied changes but "There are no changes to be applied"
    Posted Aug 21, 2017 11:42 AM
    The user was able to remove that change from airwave. But still, I am not able to make changes, because supposedly there are not changes to be applied...
