AirWave 8.2.4.1 - Supported IAP software versions
  • 1.  AirWave 8.2.4.1 - Supported IAP software versions
    Posted Sep 20, 2017 10:38 AM
    I have a customer running AirWave 8.2.4.1 and IAP-315-US clusters, currently running ArubaInstant_Hercules_6.5.1.5-4.3.1.4 code.  We need to add AP-365 devices into these clusters.  What is the highest supported conservative code release that is supported by AirWave 8.2.4.1?  Is Instant 6.5.3.0 the highest supported release?  Will Airwave support Instant 6.5.3.2?  Are there any known ClearPass authentication issues with these code releases?
  • 2.  RE: AirWave 8.2.4.1 - Supported IAP software versions
    Posted Oct 03, 2017 04:51 PM
    HI, look at here
    Instant Version: 6.5.2
    Support for: AirWave 8.2.4 Template Config & Instant GUI Config
