Network Management
Airwave 8.2.7.1 - How can I view AP configuration backups and/or restore?
  • 1.  Airwave 8.2.7.1 - How can I view AP configuration backups and/or restore?
    Posted Jan 08, 2019 04:29 PM
    Hi all,
    I'm new to Aruba and Airwave.
    I have added my virtual chassis and APs to Airwave using a variety of groups.
    I'm trying to understand how Airwave manages backups of the AP's configurations.
    is there a place in AirWave where I can see the config backups and/or restore the config to the AP?
  • 2.  RE: Airwave 8.2.7.1 - How can I view AP configuration backups and/or restore?
    Posted Jan 09, 2019 11:06 AM
    Under config page you see the device configuration if you are using template mode, if instant is enabled the you will see the archeived config in Groups>Instant page
  • 3.  RE: Airwave 8.2.7.1 - How can I view AP configuration backups and/or restore?
    Posted Jan 09, 2019 11:37 AM
    what is the difference between "Template mode" and "Instant mode"?
  • 4.  RE: Airwave 8.2.7.1 - How can I view AP configuration backups and/or restore?
