Network Management
AirWave 8.2.7.1 VM Requirements
  • 1.  AirWave 8.2.7.1 VM Requirements
    Posted Nov 08, 2018 03:10 AM
    I want to update AirWave to the latest version 8.2.7.1. I can not find the minimum requirements for a VM virtual machine anywhere.
    I have about 130 Access Points connected to AirWave (8.2.5) at the moment.
    https://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/EntryId/31022/Default.aspx
    Here are only the requirements for Hardware. Please help.
    Regards
  • 2.  RE: AirWave 8.2.7.1 VM Requirements
    Posted Nov 08, 2018 03:23 AM
    If it is on VM need to allocate 20% more resoruces, compare to Hardware. In server sizing guide , you can find this detials.
  • 3.  RE: AirWave 8.2.7.1 VM Requirements
    Posted Nov 08, 2018 03:29 AM
    Hi Pavan,
    unfortunately, I can not find exact requirements anywhere in the documentation.
    Please help.
  • 4.  RE: AirWave 8.2.7.1 VM Requirements
    Posted Nov 08, 2018 03:46 AM
    How much memory/CPU cores allcoated in current 8.2.5 server, there is no change in resource requirment between 8.2.5 to 8.2.7.1.
  • 5.  RE: AirWave 8.2.7.1 VM Requirements
    Posted Nov 08, 2018 03:57 AM
    However, I would like to know the official requirements. At the moment I have 2 Core and 8GB RAM.
    I wonder, do I add something more before updating to 8.2.7.1?
    See attached Performance (134 AP's connected to AirWave).
  • 6.  RE: AirWave 8.2.7.1 VM Requirements
    Posted Nov 08, 2018 05:46 AM
    Two cores is not sufficient, increase to 6 cores and memory to 16GB.
  • 7.  RE: AirWave 8.2.7.1 VM Requirements
    Posted Nov 08, 2018 05:53 AM
    4 Cores and 16GB will be not ok?
    Can I just turn off the server, add Cores/RAM and run again without making changes to the AirWave
    Regards
  • 8.  RE: AirWave 8.2.7.1 VM Requirements
    Posted Nov 08, 2018 05:57 AM
    Yes, its fine, shutdown the instance, increase resources and poweron.
  • 9.  RE: AirWave 8.2.7.1 VM Requirements
    Posted Nov 08, 2018 06:05 AM
    Are you sure that I need 6 Cores, if <150 Access Points is connected to AirWave?
    Regards
