Network Management
Airwave 8.2.8.2 Aruba controller 'Advanced Monitoring'
  • 1.  Airwave 8.2.8.2 Aruba controller 'Advanced Monitoring'
    Posted May 20, 2019 11:22 PM
    In 8.2.8.2 there appears to be a new tab on the Devices->Montitor page called 'Advanced Monitoring'.
    When I click this I can see device info such as Hostname, IP, Firmware.
    All the other fields/tables/graphs are blank: WAN, Performance, VPN tunnels.
    There are definitely multiple VPN tunnels terminating on this MC, and this is shown in other Airwave screens.
    The device I'm trying to view is a 7010 running 8.4.0.2, in standalone mode. AMON is enabled.
    Is there something I need to configure to get data appearing on this Advanced Monitoring screen? Maybe this screen is only for SD-WAN devices?
  • 2.  RE: Airwave 8.2.8.2 Aruba controller 'Advanced Monitoring'
    Posted May 21, 2019 08:37 AM
    WAN tunnels will show only if you add both branch office controller (BOC) and VPN controller (VPNC) in Airwave.
    We have few issues related to proper WAN data not updating in Airwave which will be get fixed in future Airwave release.
  • 3.  RE: Airwave 8.2.8.2 Aruba controller 'Advanced Monitoring'
    Posted Aug 03, 2020 05:13 AM
    Hi
    it now AirWave  8.2.11.0 and still not working , is i should do any additional configuration to make it work
    thanks
  • 4.  RE: Airwave 8.2.8.2 Aruba controller 'Advanced Monitoring'
    Posted Aug 04, 2020 07:44 AM
    Are you not seeing Advanced monitoring data for both BOC and VPNC controllers in Airwave.
    Have you added airwave as management server and in management profile does this stats are enabled?
    Stats                               Enabled
    Stats_Ext                           Enabled
    WAN State Info                      Enabled
    In my running config have below config and shows data in my server.
    uplink wired vlan 12 uplink-id name uplink_mpls_12_13_mpls
       wan-type MPLS
       weight 10
    uplink wired vlan 94 uplink-id name uplink_inet_94_90_inet
       wan-type Internet
       weight 10
    uplink health-check ip xxx.arubanetworks.com
    uplink health-check
    uplink load-balance mode uplink-utilization
