Please refer to Virtualization section in the AirWave sizing guide:
https://www.arubanetworks.com/techdocs/AirWave/830/pdfs/AirWave_8.3.0_Server_Sizing_Guide.pdf
Please note that 8.2.9/10 is EOS for a while. The underlying CEntOS is EOL in June. you should plan to move to RHEL8 based 8.3 AirWave version. Please work with support for the migration path and steps.
Regards
Gowri Amujuri
Original Message:
Sent: Aug 16, 2024 06:07 AM
Subject: AirWave 8.2.9 and 8.2.10 Virtual Machine Requirement
Hi, need help about my setup spec requirements for the RAM,CPU and Hard disk because current running airwave seems like having performance issue due to the maybe low specification.
This is a campus setup with 12 controllers and 3238 mix of aruba 505,515,535,555 and 575 AP. and sometimes in the future, planning to increase the number of AP to almost 4000 AP. and active client somehow can reach around 12k users.
current spec is
thanks for the help and info in advance
Original Message:
Sent: Nov 19, 2019 08:07 AM
For VM envorinment to montior your current network devices count, below resource needed to be allocated
RAM - 16GB
CPU -6 Physical Cores Intel Xenon
Hard disk: 400GB
