Network Management
Airwave Alerts
This thread has been viewed 1592 times
  • 1.  Airwave Alerts
    Posted Feb 10, 2014 11:01 AM
    Hello, I was wondering if there is a way to setup Airwave to check to see if Radius is authenticating wireless users and if it is not to send an email or some type of alert telling me so?
  • 2.  RE: Airwave Alerts
    Posted Feb 17, 2014 09:20 AM
    You bet.
    1. Make sure you have enabled SNMP traps on your controller to be sent to Airwave.
    2. Create an AMP trigger using the Radius Authentication issues Type
    Choose either Client or Device, you can select a count (how many times you want it to occur before being triggered).
    As a side, you can also have a report created and emailed to you daily.
  • 3.  RE: Airwave Alerts
    Posted Jul 16, 2014 02:42 AM
    Hi Guys
    Can Alerts  be triggered to Airwave management once a user gets close to reaching their limit.
    Maybe a Radius attribute sent to Airwave?
    How can we do this please?
    Harry
  • 4.  RE: Airwave Alerts
    Posted Jul 16, 2014 02:46 AM
    mahathma wrote:
    Hi Guys
    Harry
    Close to reaching what specific limit mahathma?
  • 5.  RE: Airwave Alerts
    Posted Jul 16, 2014 03:24 AM
    Hi Colin
    When a user reached their allocated quota of say 1GB, I know radius can send COA attribute and Instant AP can change role.
    Can an alert be sent to Airwave by radius once this limit is reached?
  • 6.  RE: Airwave Alerts
    Posted Jul 16, 2014 03:26 AM
    A separate system must be in place besides airwave to monitor the bandwidth, send a COA and send Airwave a trap or syslog message.  Airwave can then look for that syslog or trap.
  • 7.  RE: Airwave Alerts
    Posted Jul 16, 2014 03:41 AM
    Thanks Colin
  • 8.  RE: Airwave Alerts
    Posted Jan 13, 2017 01:30 AM
    Dear Friends,
    I also have similar question but little different is that
    I want to get alerted when any device down from airwave .
    I configured as follows
    system>triggers>add .  then filled all the required fields.  there was alert setting lowest time was 5 minutes.
    For testing purpose, I removed Access Point from the network for 25-30 Minutes but I did not receive an email alert.
    Please suggest me to get alerted.
    Thank you so much in advance.
    Regards
    Ambaraya
  • 9.  RE: Airwave Alerts
    Posted Jan 13, 2017 06:22 AM
    Does the access point show as "Down" in Airwave?
  • 10.  RE: Airwave Alerts
    Posted Jan 13, 2017 06:44 AM
    Hello CJ,r
    thank you for your reply. Yes it was showing down in airwave.
  • 11.  RE: Airwave Alerts
    Posted Jan 13, 2017 06:49 AM
    Can we see screenshots of your rule in Airwave?
  • 12.  RE: Airwave Alerts
    Posted Jan 13, 2017 07:12 AM
    Sure, CJ.
    Please find attached screenshots.
  • 13.  RE: Airwave Alerts
    Posted Jan 13, 2017 07:15 AM
    Please try to get it working with the attached settings, first.
    Also make sure that the controller is sending snmp traps to Airwave.
  • 14.  RE: Airwave Alerts
    Posted Jan 13, 2017 07:36 AM
    Okay I will Check.
  • 15.  RE: Airwave Alerts
    Posted Jan 16, 2017 07:54 AM
    Hey Hi,
    As you told me to check only basic configuration, But it is not taking.
    Please find the screenshot for your reference.
    Please suggest me.
    Thank you
  • 16.  RE: Airwave Alerts
    Posted Jan 16, 2017 08:00 AM
    Hi
    I have one more doubt, What is sender address ?
    what i have to put there?
    PFA.
  • 17.  RE: Airwave Alerts
    Posted Jan 16, 2017 08:15 AM
    @ambaraya wrote:
    Hey Hi,
    Please suggest me.
    Thank you
    Please check "Send Alerts when upstream device is down" to yes.
    Also, you should be able to see the "Alerts" counter in Airwave go up and see the device as down when the controller sends a trap or Airwave has seen the device as down for 5 minutes.
    You need to see this before moving onto email alerts.
    The sender address should not matter.  The built-in email server should work as long as your DNS server has correct MX records for your domain.  If that does not work, you will have to setup a relay http://community.arubanetworks.com/t5/Wireless-Access/Email-Configuration/td-p/80260
  • 18.  RE: Airwave Alerts
    Posted Jan 16, 2017 10:53 AM
    Hi CJ,
    "Send Alerts when upstream device is down" to yes is there.
    and please find some more screenshots that may give some more info to you to help me.
    PFA.
  • 19.  RE: Airwave Alerts
    Posted Feb 03, 2017 07:11 AM
    Hi all,
    I want to know that CLI commands for IAPs and Virtual controller.
    Is IAP CLI commands work for Virtual controller?
    Please share here.
    Thanks in advance
