Airwave Amp Upgrade Failed error creating chain 'acct~i':File exists
  • 1.  Airwave Amp Upgrade Failed error creating chain 'acct~i':File exists
    Posted Mar 22, 2017 05:19 PM
    So I been trying to for 2 days to upgrade Airwave Amp. Yesterday I was going from 8.2.2 to 8.2.3.1 but had to resolve some centos update issues, but that update borked the upgrade which turned into a fiasico. Long story short I reimaged the server with our initial Airwave setup using clonezilla this morning. That took me back to ver 8.0.7.
    But then I had upgrade issues with 8.0.10:
    /usr/bin/make -C src install
    make[2]: Entering directory `/root/svn/mercury/src'
    /usr/bin/make -f Makefile.perllib remove_old_rpms
    make[3]: Entering directory `/root/svn/mercury/src'
    error: Failed dependencies:
    fontconfig-devel is needed by (installed) gd-devel-2.0.35-11.el6.x86_64
    freetype-devel is needed by (installed) gd-devel-2.0.35-11.el6.x86_64
    krb5-devel is needed by (installed) openssl-devel-1.0.1e-30.el6.8.x86_64
    libpng-devel is needed by (installed) gd-devel-2.0.35-11.el6.x86_64
    make[3]: Leaving directory `/root/svn/mercury/src'
    /usr/bin/make -C /root/svn/mercury/src/x86_64/rpms/CentOS-6 install
    make[3]: Entering directory `/root/svn/mercury/src/x86_64/rpms/CentOS-6'
    error: open of ../node_js/npm/openssl-devel-1.0.1e-30.el6.11.x86_64.rpm failed: No such file or directory
    make[3]: *** [security_patches] Error 1
    make[3]: Leaving directory `/root/svn/mercury/src/x86_64/rpms/CentOS-6'
    make[2]: *** [perllib] Error 2
    make[2]: Leaving directory `/root/svn/mercury/src'
    make[1]: *** [src_install] Error 2
    make[1]: Leaving directory `/root/svn/mercury'
    make: *** [upgrade] Error 2
    make: Leaving directory `/root/svn/mercury'
    Stopping Pound: [ OK ]
    Stopping httpd: [ OK ]
    tsdb-server: unrecognized servic
    So then I read there was an rpm package version issue and that 8.0.11.1 should have resolved it. so I tried it and got this:
    /bin/cp -f lib/conf/ld.so.conf /etc/ld.so.conf.d/airwave.conf
    /sbin/ldconfig
    tsdb-server: unrecognized service
    So I decided to run OS updates.
    First I did "yum upgrade yum rpm"
    afterwards, I did: "yum update"
    I rebooted at least 3 times today as yesterday one did not seem to be enough which start the whole fiasco with moving to 8.2.3.1.
    So now I tried to go to 8.0.11.1 again. and got the following error:
    /opt/airwave/bin/perl -MMercury::Scripts::ConfigureRedis -e 'Mercury::Scripts::ConfigureRedis->go'
    /sbin/service redis condrestart
    /opt/airwave/bin/perl -MMercury::Scripts::ConfigureFreeRadius -e 'Mercury::Scripts::ConfigureFreeRadius->go'
    bin/conf_common_post_install
    Shutting down system logger: [ OK ]
    Starting system logger: [ OK ]
    iptables: Setting chains to policy ACCEPT: filter nat [ OK ]
    iptables: Flushing firewall rules: [ OK ]
    iptables: Unloading modules: [ OK ]
    iptables: Applying firewall rules: iptables-restore v1.4.7: error creating chain 'acct~i':File exists
    Error occurred at line: 76
    Try `iptables-restore -h' or 'iptables-restore --help' for more information.
    [FAILED]
    [FAILED]
    [FAILED]
    Failed to restart iptables cleanly after 3 retries! at bin/conf_common_post_install line 31.
    make[1]: *** [conf_common_post_install] Error 1
    beam.erl: no process killed
    So I was like ok lets try 8.2.0.2 since I know it was workign for me before I had to reimage. But had the same issue is before plus some new ones:
    /sbin/service redis-vrf condrestart
    redis-vrf: unrecognized service
    make[1]: [redis_conf] Error 1 (ignored)
    /bin/cp -f lib/conf/tmux.conf /etc/tmux.conf
    [FAILED]
    [FAILED]
    [FAILED]
    Failed to restart iptables cleanly after 3 retries! at bin/conf_common_post_install line 35.
    rabbitmq-server: unrecognized service
    Wed Mar 22 14:41:32 2017: Last PID not available VisualRF Engine..
    I am at loss for what to do. I am either going to have to reimage again or start from scratch using the ISO which I don't want to do as are server had issues with the network adapter when we installed set this server up with v8.0.7. I really don't want to go down that road again. As it was not simply finding the correct nic drivers there was an issue with the amp install as well because of the nic issue.
    So can someone point me in the right direction as to why this is all borked?  I never had an upgrade issue before. I original had Aruba TAC do the 8.0.7 to 8.0.10,  I did all of the others just fine on my own after that. I have my last good backup from 8.2.2  If I can get there I will be all good again.
  • 2.  RE: Airwave Amp Upgrade Failed error creating chain 'acct~i':File exists
    Posted Mar 22, 2017 09:16 PM
    We had weird stuff with IP table too when we upgraded recently to 8.2.3. We got help from the TAC engineer specialized with AirWave and he was able to cleanup stuff in our database prior the upgrade.
    I suggest you to call the TAC to get support!
  • 3.  RE: Airwave Amp Upgrade Failed error creating chain 'acct~i':File exists
    Posted Mar 23, 2017 05:26 AM
    Hi Joe,
    • To fix uprade failed due to iptables issue, follow below steps
      #amp_enable -now
    • Flush and reset the iptables with the following commands
      #service iptables stop
      #iptables --flush
      #service iptables save
      #service iptables restart
    • Recompile the code with the make script
      #root; make | tee  /tmp/make.txt
    Pavan
    If my post address your query, give kudos:)
