Network Management
Airwave and Aruba OS compatibility
  • 1.  Airwave and Aruba OS compatibility
    Posted Sep 30, 2020 10:37 AM
    Is there any documentation or guidance on Aruba OS and Airwave version compatibility? We have a quite neglected Airwave server on an 8.2.1.1 and controllers on 8.5.0.6 which don't seem to be sharing data properly with each other. We already know we need to upgrade the Airwave server and the Aruba OS but just wanted to know how I can confirm compatibility between the two?
  • 2.  RE: Airwave and Aruba OS compatibility
    Posted Sep 30, 2020 11:08 AM
    You can refer Airwave supported guide to check compatibility. Support for 8.5.0.0 is added from 8.2.9 code. Current latest code is 8.2.11.2, which have support for 8.6.0.x & 8.7.0.x code as well.
    From 8.2.10, centos version is 7.x code. Your current server can be upgraded till 8.2.10.1 code, to upgrade to 8.2.11.0 and above, we need to migrate centos version to 7.x.
    Steps to migrate to Centos 7.
    1. Upgrade from 8.2.1.1 to 8.2.10.1 which have multiple upgrade paths.8.2.1.1> 8.2.3.1>8.2.4.1>8.2.6.1>8.2.7.1>>8.2.9.1>8.2.10.1 (Note: root access blocked from 8.2.4 code, we will have AMPCLI shell which will have limited access.)
    2. Take backup of 8.2.10.1 after upgrade.
    3. Do fresh install of 8.2.10.1 using ISO.
    4. Restore backup on newly installed server which took in step2.
    5. Now we will be able to upgrade server to 8.2.11.0 and above.
