Network Management
Airwave and ClearPass
  • 1.  Airwave and ClearPass
    Posted Sep 24, 2019 12:09 AM
    I would like to understand the concept to build the firewall rules. I need some help with that. My setup is as below:
    Clearpass mgmt --- firewall -- airwave
    clearpass data -- firewall -- airwave
    some documentation says that ClearPass alwayse initate connection through data port if it is configured.
    I would like to integrate ClearPass with Airwave so from the ClearPass log you can click to Airwave portal and follow the user in Airwave.
    I have to write up the firewall rules but not sure if it is
    Airwave -- Clearpass mgmt -- 161
    clearpass data -- airwave -- 162
    or
    clearpass mgmt -- airwave -- 162
    or
    Airwave -- Clearpass data-- 161
    if some one please explain that will be huge help.
    Thanks in advance.
  • 2.  RE: Airwave and ClearPass
    Posted Sep 24, 2019 04:49 AM
    https://community.arubanetworks.com/t5/Security/CPPM-data-port-and-mgmt-port/td-p/150802
    link explains data and managment port usage.
    Allows both 161 & 162 ports on your firewall,  161 port is used by Airwave for snmp get/set operation where as 162 port is used to receive CPPM syslog and events in Airwave.
