Network Management
Airwave and Mobility Controller
  • 1.  Airwave and Mobility Controller
    Posted Oct 01, 2014 06:18 AM
    I would like to add our mobility controller to an AirWave which is accessible over Internet.
    The controller is in 6.3.1.4 and I added the AirWave server using the Wizard.
    I have mostly worked with Instant and add the IP address of the server on the VC interface was the only thing to do to see it in 'New Device'.
    However, just by doing the wizard on the controller and put the SNMP community, I can't see it on the AirWave, even if I can see some AppRF information.
    Do I have to add it manually ?
    Thanks in advance.
    - nice2k.
  • 2.  RE: Airwave and Mobility Controller
    Posted Oct 01, 2014 07:33 AM
    If you go to device setup, click Add, select Aruba device and fill in the appropriate information.
  • 3.  RE: Airwave and Mobility Controller
    Posted Oct 01, 2014 08:40 AM
    Thanks, problem is solved.
    I needed to add it as you said, but also to redirect SNMP and SSH ports on my local firewall to the controller.
    Thanks.
    nice2k.
