Network Management
AirWave and nested groups
  • 1.  AirWave and nested groups
    Posted Apr 14, 2014 10:27 AM
    I'm working through setting up and importing devices into AirWave, and I'm getting ready to import some APs into it.  Our consultant created a couple of them, but I can't remember the process to create a new sub-group under the Access Point group, and can't find anything in the documentation.  Can someone help refresh my memory?
    thanks all
    SJ
  • 2.  RE: AirWave and nested groups
    Posted Apr 14, 2014 10:32 AM
    Groups are for if you want to setup configuration for your controllers/devices in Airwave and push them to devices.  You cannot create sub-groups.
    You probably want Folders, which CAN be hierarchical.  When you enter a folder, you should see the NEW FOLDER link in the lower left hand corner of the page.
  • 3.  RE: AirWave and nested groups
    Posted Apr 14, 2014 10:47 AM
    Ah--that makes more sense!  Still trying to get a handle on terminology.
    Thanks again!
  • 4.  RE: AirWave and nested groups
    Posted Oct 27, 2017 03:42 PM
    I know this is old, but in case someone else runs across this. . You can have nested groups. You can only have a maximum of two levels, though.
