Network Management
Airwave and Servicenow integration
  • 1.  Airwave and Servicenow integration
    Posted Mar 26, 2019 02:55 AM
    We have airwave to manage our aruba network devices. We have configured Airwave to generate a mail when a device goes down. We would like to generate a ticket automatically in Servicenow..Is there any possible way to integrate Aruba Airwave and Servicenow????
  • 2.  RE: Airwave and Servicenow integration
    Posted Mar 26, 2019 03:53 AM
    Currently this is not supported. You can raise a feature request for the same.
  • 3.  RE: Airwave and Servicenow integration
    Posted Mar 27, 2019 06:42 AM
    Is there any API available to do airwave integration with Service Now??
  • 4.  RE: Airwave and Servicenow integration
    Posted Mar 27, 2019 10:35 PM
    Airwave integration with service now is not supported as of now and will be a feature request.
    API are available on Airwave however, not sure if that helps with integration with service now. You can see the available APIs under Home --> Documentation tab when you login to Airwave.
  • 5.  RE: Airwave and Servicenow integration
    Posted Mar 27, 2019 10:59 PM
    currently i can think of no other option.
    But i researched and reached this https://techyhost.com/free-data-monitoring-apps/ in which airwave and service integration is explained in detailed.
    Regards.
  • 6.  RE: Airwave and Servicenow integration
    Posted May 09, 2019 01:27 PM
    Please use the Alerts and Triggers section on AMP to set triggers for any event which you would want to get a service now ticket created. For all such triggers, configure Airwave to send email to service now.
    There is a way on Service now to open tickets for inbound emails.
    Quamruz.
