Aruba Apps
The HPE Aruba Networking Apps board is designed to address questions, comments, and feature requests for all HPE Aruba Networking mobile Apps
Airwave and SiteSurvey
  • 1.  Airwave and SiteSurvey
    Posted Feb 21, 2017 04:34 AM
    I planed a SiteSurvey with AirWave. After I placed all AP, I switched the Headmap on. It looked very good. I moved one AP 1m to the right. After that the headmap evaluation shows an extremely different picture. After a further refresh without changing anything  I got again an extremely changed evaluation. WHY ?
  • 2.  RE: Airwave and SiteSurvey
    Posted Feb 21, 2017 06:39 AM
    On what band did you see a different picture, the 5ghz or 2.4ghz?  It can take some time for a single AP to scan through all of the channels to draw a picture, so it is possible that you were not receiving a complete picture the first time you looked at the heat map...
  • 3.  RE: Airwave and SiteSurvey
    Posted Feb 21, 2017 07:28 AM
    Thanks for your answer, but it is a planing not are monitoring
  • 4.  RE: Airwave and SiteSurvey
    Posted Feb 21, 2017 07:30 AM
    Okay.  Planning.  Got it.
    Which parameters did you use as input?  How many APs are being placed?  What is the square footage of the area?
  • 5.  RE: Airwave and SiteSurvey
    Posted Feb 21, 2017 07:46 AM
    12544qm²
    35 AP 215
    Headmap with 2,4 and 5 Ghz
    show only this floor.
    It is a Hall with racks in it and one office with 4 rooms on the same flour.
    Concrete Wall outside
  • 6.  RE: Airwave and SiteSurvey
    Posted Feb 21, 2017 08:02 AM
    How did you get the AP number?
    How did you come up with 35 APs for that space?
  • 7.  RE: Airwave and SiteSurvey
    Posted Feb 21, 2017 05:18 PM
    It is a manual planing
    and a planing where AP can fall out.
    why do you mean it is to much ?
    But why do you have these questions?
    My problem is that if i refresh, he didn´t shows me the headmap for all AP only for the AP on the left site. But I chanced nothing only moving one AP 1 m to the right site.
  • 8.  RE: Airwave and SiteSurvey
    Posted Feb 21, 2017 07:14 PM
    I am asking because with that number of APs in a small space, it might not show the heatmaps accurately.
  • 9.  RE: Airwave and SiteSurvey
    Posted Feb 22, 2017 05:33 AM
    The space is about 12152qm²
    Why to you mean it is a smale space.
    and where are high Racks insite The building is about 12 m high
    The racs have about 6 meters.
    Between one AP to the next are about 18 m between
    It should not a longer distance between the AP because if one ap fails the other must pick up the client asap.
    Also it is planed to use Voice in the future.
  • 10.  RE: Airwave and SiteSurvey
    Posted Feb 22, 2017 05:51 AM
    It could be a bug in the software.  Do you have an export of your RF plan that you can send?  If you PM me your email, I can send you a link to send it to me.
  • 11.  RE: Airwave and SiteSurvey
    Posted Feb 22, 2017 07:44 AM
    Thanks for your help.
    My Email Adress is ybe@aeroaccess.de
    I have a export file
