Network Management
Airwave AP Heat Map
  • 1.  Airwave AP Heat Map
    Posted Oct 03, 2014 06:56 PM
    I was wondering if anyone encountered a problem wherein, I placed an AP on VisualRF and the heatmap is not showing up.  All the other AP's on the map are showing up with the heat signal.  I have checked the 11ac and 11ng statuses and they are showing ok and there are no errors in the logs.  I have exchanged the AP with another device and the same issue occured when moved to a new location.  Additionally, I have Rebooted the AMP services to ensure that something isn't stuck with the service.
  • 2.  RE: Airwave AP Heat Map
    Posted Oct 03, 2014 07:03 PM
    Restarted AMP and it fixed the issue.
  • 3.  RE: Airwave AP Heat Map
    Posted Oct 03, 2014 07:25 PM
    Hitting the refresh button as well. Sometimes going up a floor, then back again.
