Developer
last person joined: 11 days ago
Airwave API
  • 1.  Airwave API
    Posted Mar 08, 2023 02:07 AM
    Hi!
    I have a question about the Airwave API. Is it possible to disable the token or automatically refresh him?
    thx
    frenz
    Aruba - What else?
  • 2.  RE: Airwave API
    MVP GURU
    Posted Mar 21, 2023 05:47 PM
    do you have try to use DELETE method HTTP ? on the token ?
    PowerArubaCL: Powershell Module to use Aruba Central
    ACEP / ACMX #107 / ACDX #1281
