Network Management
Airwave API to Retrieve Reports or Send Reports with ftp or scp
  • 1.  Airwave API to Retrieve Reports or Send Reports with ftp or scp
    Posted May 08, 2014 09:19 PM
    Is there a way to use the Airwave XML API to retrieve reports?  We'd like to use a cron job to download and save reports from the Airwave.  I've seen sample code for a few things but nothing related to reports.  Is there an API reference? Or as an alternative, is there a way to deliver reports using ftp or scp instead of email?
    Thanks!
  • 2.  RE: Airwave API to Retrieve Reports or Send Reports with ftp or scp
    Posted Apr 09, 2015 05:45 AM
    Anyone knows something abouts this? API and reports possibilities?
  • 3.  RE: Airwave API to Retrieve Reports or Send Reports with ftp or scp
    Posted Apr 10, 2015 11:48 AM
    The APIs will not access this feature, it'd be an RFE to add this ability to the APIs.
    What version of AirWave are you running?  If you're running AMP 8.0 or newer, there should be options in the report definition:
    It allows you to directly export reports over FTP or SCP in both CSV and PDF formats.  Make sure the path is a valid path.
