Network Management
aIrwave as TFTP Dump server for IAP
  • 1.  aIrwave as TFTP Dump server for IAP
    Posted Dec 20, 2017 07:19 PM
    Just wondering if Airwave can be set as a TFTP dump server for Instant APs or if this must be a standalone device?
    Scott
  • 2.  RE: aIrwave as TFTP Dump server for IAP
    Posted Dec 28, 2017 04:19 AM
    a. It should be ok to set up tftp server on amp before 8.2.4.
    b. After 8.2.4, we can't set up tftp server with same set up steps, we always get transfer timeout message.
    c. Upgrading amp may remove iptables we created before upgrade.
    d. Here is steps to set up tftp server on amp before 8.2.4.
    1.
    modify tftp client config file
    [root@localhost xinetd.d]# vi /etc/xinetd.d/tftp
    service tftp
            socket_type             = dgram
            protocol                = udp
            wait                    = yes
            user                    = root
            server                  = /usr/sbin/in.tftpd
            server_args             = -s /root/dump -c
            disable                 = no
            per_source              = 11
            cps                     = 100 2
            flags                   = IPv4
    “/root/dump” is tftp root path
    2.
    modify tftp server config file
    vi /etc/xinetd.d/tftpd
    service tftp
      disable        = no
      socket_type    = dgram
      protocol       = udp
      wait           = yes
      user           = root
      server_args    = -s /root/dump -c -T 600000 -v
      per_source     = 11
      cps            = 100 2
      flags          = IPv4
    3.
    restart tftp process
    [root@localhost tftpboot]# service xinetd restart
    Stopping xinetd: [  OK  ]
    Starting xinetd: [  OK  ]
    4.
    modify iptables, please backup iptables before changing.
    # sudo /sbin/iptables -I INPUT -p udp --dport 69 -j ACCEPT
    # sudo /sbin/iptables -I INPUT -p udp --sport 69 -j ACCEPT
    # sudo /sbin/iptables -I OUTPUT -p udp --sport 69 -j ACCEPT
    # sudo /sbin/iptables -I OUTPUT -p udp --dport 69 -j ACCEPT
    # sudo /etc/rc.d/init.d/iptables save
    # sudo service iptables restart
  • 3.  RE: aIrwave as TFTP Dump server for IAP
    Posted Jan 07, 2018 06:08 PM
    thanks wdeng. its a shame this isn't an built in feature of Airwave.
