Network Management
Airwave can saw configuration change on MM or MC
  • 1.  Airwave can saw configuration change on MM or MC
    Posted Jun 04, 2021 04:12 AM
    Dear all
    I would like to find configuration change on MM and MC in the past like a someone change configuration on MM and MC
    Can The Airwave see it ?
    jakkapan meeon
  • 2.  RE: Airwave can saw configuration change on MM or MC
    MVP GURU
    Posted Jun 04, 2021 06:35 AM
    Have you tried running the "show audit-trail history" command. Is that giving you enough information on configuration changes?
    Dustin Burns
    Senior Mobility and Access Engineer @WEI
    ACCX 1271| ACMX 509| ACSP | ACDA | MVP Guru 2021
  • 3.  RE: Airwave can saw configuration change on MM or MC
    Posted Jun 04, 2021 06:57 AM
    Hi Dustin
    I will try this command
    thank you for information
    jakkapan meeon
  • 4.  RE: Airwave can saw configuration change on MM or MC
    Posted Jun 05, 2021 04:54 AM
    Hi Dustim
    I did show command it show last configuration change but configuration some it lost
    This log show only 23 MAY to present
    But i need look configuration on 20-22  MAY
    Do you have any idea ?
    Thank you
    jakkapan meeon
  • 5.  RE: Airwave can saw configuration change on MM or MC
    MVP GURU
    Posted Jun 07, 2021 08:43 AM
    Did the device reboot around the time your logs stop (May 23rd) ? If a device reboots you wont see this. If the changes were made via the Mobility Master, and that has been up longer, you may be able to see it there. Change Directory to the folder the Controller is in and run it, and also change directory to the controller level and run it. You may find something there.
    Do you use TACACS+ for your access to the devices? You may have logs on the TACACS+ server for the sessions.
    Dustin Burns
