Network Management
Airwave, Clarity and now Glass ..... how do they fit together
  • 1.  Airwave, Clarity and now Glass ..... how do they fit together
    Posted Apr 11, 2017 05:58 AM
    While browsing the downloads section of support.arubanetworks.com I noticed another ova file has apeared under the Airwave folder. Having  built a clarity engine and linked it into our airwave server, what does glass do ? A glance at the PDF seems to say it's a front end for multiple Airwave servers. If youve got 1 server, any point in Glass ? Given Airwaves limited SNMP support for non Aruba kit, does Glass manage other vendors?
    Rgds
    Alex
  • 2.  RE: Airwave, Clarity and now Glass ..... how do they fit together
    Posted Apr 11, 2017 06:15 AM
    Glass is a “next-gen” master console designed from grounds up using cloud computing technologies with a lot of new capabilities compared to its predecessor! Glass 1.0 offers the following
    1. High performance and scalable platform
    a. Scales to 30,000 network devices and 300,000 client devices for Aruba WLAN (AMON only)
    b. Scales to 50,000 network devices and 500,000 client devices for 3rd party WLAN (SNMP only)
    2. Next gen aggregate dashboards
    a. Snapshot and time trend views
    b. Overview, RF health, AppRF, UCC, Clarity & Client Session dashboards
    3. New framework for aggregate reporting
    a. Summarized “executive” reports with the ability to customize with logos etc.
    4. Built-in Single Sign On (SSO) for easy navigation between AMPs and Glass
    5. Advanced Search
    a. Search for Network Devices, Clients, Folders, Floors, Rogues
    b. Partial search, prefix search depending on search parameters
    c. Granular filters
    6. Aggregate views for VisualRF and RAPIDs
    7. RBAC for administrative access
    8. Cloud based modular image upgrade process
    Glass is next generation of master console, which manages mutliple primary servers which manages/montior mulit vendor products.
    Pavan
    If my post address your query give kudos:)
  • 3.  RE: Airwave, Clarity and now Glass ..... how do they fit together
    Posted Apr 11, 2017 01:58 PM
    Where can we get support for Glass? I'm trying to deploy and it doesn't seem to be communicating with the first AirWave server I tried to link it to? I get "Waiting to hear" for the "Last Heard" value. It doesn't appear I can do anything else within Glass at the moment.
  • 4.  RE: Airwave, Clarity and now Glass ..... how do they fit together
    Posted Apr 12, 2017 04:38 AM
    Hi ,
    As per my knowledge support started from April 10th 2017, but I am not exactly sure, please check with your Aruba sales team for more details.
    Have you installed Glass on physical machine or Virtual ? Currently Glass is supported only on VMware.
    Pavan
    If my post address your query, give kudos:)
  • 5.  RE: Airwave, Clarity and now Glass ..... how do they fit together
    Posted Apr 20, 2017 12:09 PM
    Any benefit from running Glass with a single instance of AirWave?
  • 6.  RE: Airwave, Clarity and now Glass ..... how do they fit together
    Posted Apr 20, 2017 12:43 PM
    There is no benfit if you have only one managed AMPs, since all the clarity, AppRF, reporting information will get from the same server. Airwave Glass is used in mulitple managed AMP scenario.
    Pavan
  • 7.  RE: Airwave, Clarity and now Glass ..... how do they fit together
    Posted Apr 24, 2017 12:24 PM
    There is a requirement that AMP needs to be running on 8.2.3.1 for Glass to work. What version of AMP do you have running?
  • 8.  RE: Airwave, Clarity and now Glass ..... how do they fit together
    Posted Apr 24, 2017 12:40 PM
    We need to be on AMP 8.2.3.1 and need to add with FQDN managed AMP not IP in Glass.
    Pavan
  • 9.  RE: Airwave, Clarity and now Glass ..... how do they fit together
    Posted Apr 24, 2017 12:59 PM
    Hi Pavan,
    We're on 8.2.3.1, and did use a FQDN. Interestingly, Glass never seemed to get fully connected, but it did insert its hostname in Airwave under the CAS field, which then popped into the URL at logout.
  • 10.  RE: Airwave, Clarity and now Glass ..... how do they fit together
    Posted Apr 11, 2017 06:21 AM
    We have few challanges in using master console, to overcome those challanges Aruba introuced Glass 1.0
    Pavan
  • 11.  RE: Airwave, Clarity and now Glass ..... how do they fit together
    Posted May 23, 2017 11:09 PM
    Hi Pavan,
    How about configuration management and making configuration(Template/GUI) changes via Airwave. Is Aruba Glass able to do that?
  • 12.  RE: Airwave, Clarity and now Glass ..... how do they fit together
    Posted May 24, 2017 12:50 AM
    Right now it doesn't support configuration, and belive me it's also a feature we are asking dying to have.
  • 13.  RE: Airwave, Clarity and now Glass ..... how do they fit together
    Posted May 24, 2017 09:48 AM
    Does anyone actually have Glass working, and with how many AMPs? We have more than 5 AMPs and Glass 1.0.1-1 will not communicate with all of them regularly. While I would love for Glass to manage the configuration of the connected AMPS, I would prefer Glass do a better job of being a monitoring console first.
  • 14.  RE: Airwave, Clarity and now Glass ..... how do they fit together
    Posted May 24, 2017 09:51 AM
    Hi
    Open TAC ticket to look in to this issue.
    Pavan
  • 15.  RE: Airwave, Clarity and now Glass ..... how do they fit together
    Posted Jul 14, 2017 05:03 AM
    Not to be like that but the latest releases has been really bad in terms of "working".
    Clarity Synthetics and now Airwave Glass.
    Can´t even make em work out of the box with a supersimple labb setup.
    And before you say anything, a TAC case with synthetics has been opened for months where they do not get it to work. I really stopped bothering..
    The software side of things are not Arubas stong side the last year with multiple bugs (severe) on released AP code, multiple months for support in Airwave on IAP code / hw platforms etc.
    What is going on?
