Aruba Apps
last person joined: 9 days ago
The HPE Aruba Networking Apps board is designed to address questions, comments, and feature requests for all HPE Aruba Networking mobile Apps
Airwave - Clearpass (CP) Authentication (NAS-PORT-TYPE)
  • 1.  Airwave - Clearpass (CP) Authentication (NAS-PORT-TYPE)
    Posted Sep 12, 2023 02:11 PM
    We are using CP for authentication onto our wireless system and our Mobility devices (MCr/MM n MC/MDs) and for CP itself.
    I now want to add Airwave authentication via Radius to CP.  However, this is currently failing w/ a general Radius error.
    When I authentication into our MCr cluster, I see an entry in CP that shows the NAS-PORT-TYPE = 5
    When I authentication into our Airwave, I see an entry in CP that shows the NAS-PORT-TYPE = 15
    CP is configured (by our original consultant) to leverage NAS-PORT-TYPE = 15 for "wired" clients on our building networks.
    The Airwave auth is matching this and trying to authenticate w/ 802.1x Certificate information (which does not exist on Airwave.
    Basically, it is matching into the wrong "Services" object.
    Is it possible to have Airwave use NAP-PORT-TYPE = 5, like the Mobility devices all use?
    MIke
  • 2.  RE: Airwave - Clearpass (CP) Authentication (NAS-PORT-TYPE)
    Posted Sep 13, 2023 06:25 AM
    You probably want/need a separate service in ClearPass for AIrwave, where you can put that before the conflicting service and have a service matching rule for the NAS-IP of your Airwave, or for Port-Type 15.
    Also, you could consider the Airwave Admin authentication via TACACS+, but RADIUS should probably work with a separate service.
    Airwave would need the Admin Role to be returned, where your 802.1X returns user-roles, which is why you probably would need a separate service; and besides that you in general cannot change the port-type on devices/servers, it probably won't help you here.
    I'd recommend to go back to your consultant, or find another consultant with your Aruba partner unless you understand how ClearPass works.
  • 3.  RE: Airwave - Clearpass (CP) Authentication (NAS-PORT-TYPE)
    Posted Sep 13, 2023 03:03 PM
    Herman, I appreciate the reply.  But, I was asking solely is it possible to have Airwave return the same code like the other Aruba products return (type = 5).  I am thinking via a setting or a feature request.
    I have already created a separate rule and it is running before the other rule, but I would prefer to have my user rules up top and then my admin rules below.
    The above requires me to have an admin rule up top.
    Overall, I do understand Clearpass very well.
    Thanks again.
    Mike
  • 4.  RE: Airwave - Clearpass (CP) Authentication (NAS-PORT-TYPE)
    Posted Sep 20, 2023 08:01 AM
    Ah, that may be why I prefer to start with the admin services on top of my service list.
    Yes, you can go through a a feature request (innovate.arubanetworks.com), if you can't in a different way change the service rules or service order, or change to TACACS for the Airwave admin authentication.
  • 5.  RE: Airwave - Clearpass (CP) Authentication (NAS-PORT-TYPE)
    Posted Sep 20, 2023 10:07 AM
    Hi Herman,
    TY U for the reply.  I always appreciate your posts (and I learned a lot from your Aruba videos back in 2019.)
    Re: Rule order, the consultant setup things up w/ the User rules on top and Admin below, so that is why I want the rule below (to stay grouped), but as you have wisely mentioned, I will consider moving the group up.  I have not really thought about it.  Something for me to ponder.
    As for this issue, I finally received a reply from a level II member in Tech indicating I should use peap-MSCHAPv2 vs. PAP.    PAP will return 15 while peap-MSCHAPv2 will return 5 (the value I am looking for).
    I will look into this change and once implemented, I will post results/findings back to this community.
    Thanks again.
    Mike
  • 6.  RE: Airwave - Clearpass (CP) Authentication (NAS-PORT-TYPE)
    Posted Sep 21, 2023 02:53 AM
    For the AirWave service I usually use just a NAD-IP-Address to be equal to AirWave IP.
    Best, Gorazd
    Gorazd Kikelj
    MVP Expert 2023
