Network Management
Airwave / Clearpass interaction
  • 1.  Airwave / Clearpass interaction
    Posted Mar 15, 2021 09:45 AM
    snmp v3 for clearpass interaction
    I've linked our cppm master publsher into Airwave using snmp V2C but when i try using snmp v3 i get a message saying access denied ( fairly sure I've got the v3 credentials correct) Found an article from 2015 saying that you had t oalso do some CLI database command to get V3 to work. but given that a V8 airwave server has a restricted shell, guess you canty do that now
    My cppm server is in its own group in Airewave and the group is configured to use snmpv3
    For Airwave 8.2.12.1 should I need to do anything from the command line to get Airwave to interact with clearpass using snmpv3?
    Rgds
    Alex
    Alex Sharaz
  • 2.  RE: Airwave / Clearpass interaction
    Posted Mar 15, 2021 02:19 PM
    Could we check whether Group --> Basic page have SNMPv3 enabled on Airwave? We could also try going to CLI option 3(Configuration) --> 5(sshd) --> 2(Use Compatible Ciphers)
    Vishnu Mannil
    Aruba ERT
    If my post addresses your query, give kudos :)
