Network Management
Airwave cli uplaod of file using different scp port
This thread has been viewed 23 times
  • 1.  Airwave cli uplaod of file using different scp port
    Posted May 17, 2021 10:47 AM
    I need to upload a firmware upgrade file to an aurwve server running 8.2.7.1  ( 8.2.10.1) via the cli upload command . Unfortunately the hoat I'm pullingit from is behind a firewall that does port translation  so  normlly I'd do
    scp -c..... -p 446 <username>@<host>:<directory and file> ./
    How do i specify the  port to use from the restricrted ampadmin menue?
    Rgds
    Alex
    Alex Sharaz
  • 2.  RE: Airwave cli uplaod of file using different scp port
    MVP EXPERT
    Posted May 17, 2021 06:50 PM
    No idea but my solution would be to connect a SCP server directly into the Airwave Management VLAN to avoid this. For example a Rasberry PI with a standard image runs SSH/SCP. Or install a Turkey Linux Files Server .ova template that can be installed in 5 minutes on VMware. https://www.turnkeylinux.org/fileserver
    Marcel Koedijk | MVP Guru 2021 | ACMP | ACCP | ACDA | Ekahau ECSE | Not an HPE Employee | Opionions are my own
