Network Management
Airwave Configuration API
  • 1.  Airwave Configuration API
    Posted Feb 22, 2017 03:48 PM
    My question is similar to this post.
    I am looking to perform some management tasks via the API to Airwave.  I have found where you can pull statics and rename VisualRF campus through it but I cannot seem to locate any documentation around any other configuration tasks.  I did find mention of "New Configuration API" was introduced in 8.0.6 but no info around what this actually means.
    Release Notes for 8.0.10, top of page 15.
    Specifically, I am looking to move APs/VCs from one configuration group to another via an automated process rather than logging in and clicking around a lot.  Is this possible?
    I did also go looking in the documentation link within Airwave but I am running the Dell versions and don’t seem to have the same links.
    Thank you.
  • 2.  RE: Airwave Configuration API
    Posted Feb 23, 2017 05:27 AM
    I have attached the API document for your reference. Hope its helpful.
    Vishnu
    Attachment(s)
    pdf
    api guide.pdf   112 KB 1 version
  • 3.  RE: Airwave Configuration API
    Posted Feb 28, 2017 05:26 PM
    That is very helpful.
    Is it safe to assume if a feature isnt in that guide it doesnt exist?  I dont see any info about how to move APs/VCs from one group to another.  I see how to pull the AP detail but not to make a move.
    Thank you for the help and info.
  • 4.  RE: Airwave Configuration API
    Posted Mar 01, 2017 01:47 AM
    Currently i dont see an option to move the devices from one group to another using API. It would be a good feature request.
    Vishnu
  • 5.  RE: Airwave Configuration API
    Posted Sep 05, 2017 03:07 AM
    Which API can I use to set bandwidth speed for Aruba APs?
    Thank you very much!
