Network Management
Airwave configurations / purposes
  • 1.  Airwave configurations / purposes
    Posted May 08, 2017 06:36 PM
    Hi All,
    Just curious if anyone uses Airwave with VRRP failover configuration controllers. If so do you have both of the controllers read/write to Airwave or do you synchronize configurations between then and keep just one controller read/write, and the other read only?
    For Master-Local setups do you usually keep the locals as read-onlys and the master as read/write?
    Any input will be appreicated. Thanks.
  • 2.  RE: Airwave configurations / purposes
    Posted May 09, 2017 05:13 AM
    Are we planning to manage the devices using Airwave here? If its just for monitoring a read only user should do. However, if we are planning to push configuration we need to have the credentials for a read/write user.
    You can have a read only user for local and read/write for master however, in case you have to push any local controller specific changes from Airwave we would need the priviledge for that user. I would also request you to refer to Controller Configuration Guide on Airwave under Home --> Documentation for a better start.
  • 3.  RE: Airwave configurations / purposes
    Posted May 11, 2017 06:07 PM
    In my environment; one controller is master and the other is local.
    AP's terminate on the local controller. Airwave (in read only mode) is pointed to the local controller.
  • 4.  RE: Airwave configurations / purposes
    Posted May 12, 2017 05:23 AM
    If its just for monitoring and having the config synced, you can add both the controller on Airwave, with read only priviledge.
