Can someone let me know the commands to configure Airwave on the aruba controller which is running on 6.5.
Thanks in advance.
You can use the built in Wizard on a physical controller to do this:
Configuration > Wizards > AirWave
https://www.arubanetworks.com/techdocs/ArubaOS_651x_Web_Help/Content/ArubaFrameStyles/Management_Utilities/AW_Wizard.htm
Or CLI commands :
(Controller-Name) (config) # mgmt-server type amp primary-server <AMP IP>(Controller-Name) (config) # write mem
If you are using an IAP, then the below will also guide you through.
https://community.arubanetworks.com/aruba/attachments/aruba/Controller-lessWLANs/29/1/00003516-1.pdf
Try this: https://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/Command/Core_Download/Default.aspx?EntryId=28937
