Network Management
Airwave Controller Error Mismatch
  • 1.  Airwave Controller Error Mismatch
    Posted Jul 28, 2016 05:52 AM
    in Airwave I'm getting the following error
    then when i click on it i get this message
    i have no firewall between Airwave and this controller, i have checked the password and the community and there are true.
    i have also other controllers , that work fine with the same configuration
    I can't find the cause of this issue any help
    Regards
  • 2.  RE: Airwave Controller Error Mismatch
    Posted Jul 28, 2016 05:54 AM
    Had that problem earlier today. In my case it was a firewall policy blocking SSH towards controllers. Hope it helps.
    Alan
  • 3.  RE: Airwave Controller Error Mismatch
    Posted Jul 28, 2016 05:56 AM
    Sorry, just saw FW comment :-(
  • 4.  RE: Airwave Controller Error Mismatch
    Posted Jul 28, 2016 01:28 PM
    Hi Raouf,
    Just a quick one. Had a chat with TAC guys, and issues in my case was that SSH executed commands were not having enough time to run due to lag on LAN. Fix was to extend time allowed to 30sec (under Device Setup -> Communication). Hope it will help you as well.
    Telnet/SSH Settings
    Telnet/SSH Timeout (3-120 sec):
    Alan
  • 5.  RE: Airwave Controller Error Mismatch
    Posted Jul 31, 2016 06:27 AM
    thank you flolks,
    Alan , your proposition solved the problem
    Regards
