Network Management
Airwave: Controller read/write management cannot be configured
  • 1.  Airwave: Controller read/write management cannot be configured
    Posted Jan 30, 2019 08:31 AM
    Hello everyone, can someone help me?
    I have an Airwave instance and a virtual controller (standalone).
    Unfortunately, I can't adjust the management level so that it can be managed.
    The message is: "The following devices do no support management mode"
    Snmp is configured in version 1 / 2 and 3, monitors work too.
    The user is also stored on the controller, also the sending of CLI commands via Airwave works. What am I doing wrong ?
    Under Device -> Manage the read/write point is also grayed out.
  • 2.  RE: Airwave: Controller read/write management cannot be configured
    Posted Jan 30, 2019 11:31 AM
    What version of AirWave, firmware version / model of controller?
    Also, please double check the Aruba Best Practice guide / Supported Device guide
  • 3.  RE: Airwave: Controller read/write management cannot be configured
    Posted Jan 30, 2019 09:10 PM
    How did we add the device on Airwave? When you say virtual controller i assume you are reffering to IAP? If so IAP talks to Airwave over https and not snmp.
    In both ways as Rob mentioned please share the Airwave and controller version.
  • 4.  RE: Airwave: Controller read/write management cannot be configured
    Posted Jan 31, 2019 02:10 AM
    Hello Guys,
    thank you so far.
    Airwave is version 8.2.7.1
    The Controller is a mobility controller as VM , version 8.4.0.
    I tried the discovery way, and manually add the devices.
    Both ways work, like I said, I am able to monitor.
    But I am not able to change it to manage read/write.
  • 5.  RE: Airwave: Controller read/write management cannot be configured
    Posted Jan 31, 2019 02:18 AM
    AirWave supports only monitoring and software upgrades on Aruba devices running ArubaOS 8.0.0.0 or later. Below is a snapshot from the support guide.
  • 6.  RE: Airwave: Controller read/write management cannot be configured
    Posted Jan 31, 2019 02:20 AM
    Like I wrote in my post before:
    Regards :)
  • 7.  RE: Airwave: Controller read/write management cannot be configured
    Posted Jan 31, 2019 02:24 AM
    Right. Airwave supports only monitoring for 8.0.x and above version of the controller and not manage. That is why we see the manage option greyed out.
  • 8.  RE: Airwave: Controller read/write management cannot be configured
    Posted Jan 31, 2019 02:26 AM
    Ok now I understand !
    Shame over me :)
    Okay.
    I will now try to add the controller, and activate monitoring from start...
