Network Management
Airwave could not fetch config file form controller
  • 1.  Airwave could not fetch config file form controller
    Posted Nov 09, 2017 12:40 AM
    I added some controllers to Airwave and prompted an error in Device info .That say configration error (Telnet / SSH Error: could not fetch config file; command time-out).
    The controller is in monitor-only mode ,I found in the audit tab,The Airwave can fetch the controller configuration
  • 2.  RE: Airwave could not fetch config file form controller
    Posted Nov 09, 2017 06:45 AM
    Check controller login credentails proivded in correct in Airwave Aps/Devcies>manage page and also try increase the telnet/ssh timeout value in Devices Setup > communication page.
    Pavan
  • 3.  RE: Airwave could not fetch config file form controller
    Posted Nov 09, 2017 09:01 AM
    I increased the telnet/ssh vule to 20.That works fine!
    Thank you very much!
