Network Management
Airwave dmidecode offline installation
  • 1.  Airwave dmidecode offline installation
    Posted Jun 30, 2014 12:03 AM
    Hi Community,
    I usually do dmidecode to get the airwave (out-of-the-box 7.5.x version) sytem information but after upgrading to 7.7.x this tool does not work. I guess it needs to be installed separately. Is there a way to install dmidecode offline?
    Oliver
  • 2.  RE: Airwave dmidecode offline installation
    Posted Aug 25, 2014 11:28 AM
    To install offline, you need to download and SCP the RPM file into AirWave:
    filename = dmidecode-2.12-5.el6_5.x86_64
    ((http://mirror.centos.org/centos/6/updates/x86_64/Packages/dmidecode-2.12-5.el6_5.x86_64.rpm))
    transfer this into /var/airwave/custom
    then install:
    # rpm -i dmidecode-2.12-5.el6_5.x86_64
    After that, you should be able to run the regular command:
    dmidecode -s system-serial-number
