AirWave does not report client counts from APs on local controller
  • 1.  AirWave does not report client counts from APs on local controller
    Posted Feb 23, 2018 08:29 AM
    So, both my master and local controller are up in AirWave, I can see that some APs are on the master, others on the local controller, though, all APs on the local controller report 0 client. Which I know isn't correct since i can see clients on these APs if I go to the local controller web page.
    The total client counts displayed on the top header also affected since AirWave only count the clients from the master controller.
    Any idea ? I'm using AirWave 8.2.6.
    thanks
  • 2.  RE: AirWave does not report client counts from APs on local controller
    Posted Feb 23, 2018 08:42 AM
    What version of ArubaOS is this?
    Did you follow the instructions to add your controller to Airwave with SNMP and AMON?
  • 3.  RE: AirWave does not report client counts from APs on local controller
    Posted Feb 23, 2018 09:11 AM
    Ugh, yeah, my AirWave server wasn't defined on my local controller config!
    Thanks!
  • 4.  RE: AirWave does not report client counts from APs on local controller
    Posted Sep 24, 2019 11:53 AM
    Had exact same issue - with the exact same resolution; thanks you!
