Network Management
Airwave doesn't add devices to groups.
  • 1.  Airwave doesn't add devices to groups.
    Posted Jan 08, 2018 11:15 AM
    Hi community.
    Scenario: We have Airwave installed on a virtual machine running on VMware.
    The machine has: 1,5 Tb of storage, 128GB of ram and 12 cpus.
    Airwave ver: 8.2.4.1
    We have a two 7210 Aruba Controller on "md" mode, managed by a Mobility Master, we have configured MM and the controllers with a community string used for Airwave.
    On the airwave side these 3 devices was discovered without issues, now the problem appear:
    We go to: "AP/Devices-->New" then we see 3 new devices, we select the device to assign it to a group and when we hit the "Add" button nothing happens, even if we select, Replace Hardware, Ignore Device, Delete devices. We have search for a solution but nothing seems to work.
    Also we tried to add devices manually but a mac mismatch error showed up and we weren't able to delete the devices as I mentioned.
    Thankyou in advance.
  • 2.  RE: Airwave doesn't add devices to groups.
    Posted Jan 09, 2018 05:11 PM
    a) This will probably be handled quick in a support case
    b) try this:
    -in one browser frame: watch system -> status -> webserver log (httpd/error_log)
    -at the same time, try to add the device again
    -refresh the log, there should be a crash to some effect for why the device wasn't added
    c) another thing to check is home -> license.  I don't see any eval or license limit msg, but it's good to double check license status just in case
  • 3.  RE: Airwave doesn't add devices to groups.
    Posted Jan 11, 2018 12:04 PM
    Thank you for your reply Rob.
    So, I got a very extensive log using the httpd/error_log,
    These are the first lines: [error] [client 127.0.0.1] ERROR:  function supports_vpn_connections(bigint) does not exist
    LINE 85:         CASE WHEN supports_vpn_connections(ap.id)
    HINT:  No function matches the given name and argument types. You might need to add explicit type casts.:
        SELECT * FROM (
        SELECT
    I gonna attach a txt file with the full log error.
    Attachment(s)
    txt
    Error-Airwave.txt   8 KB 1 version
  • 4.  RE: Airwave doesn't add devices to groups.
    Posted Jan 11, 2018 12:12 PM
    Looks like there's a schema issue.  Support should be able to pinpoint the database schema change that didn't get applied to get things working again.
  • 5.  RE: Airwave doesn't add devices to groups.
    Posted Jan 11, 2018 12:23 PM
    Yes Rob, I think we should contact support now.
    Thank you for your time.
  • 6.  RE: Airwave doesn't add devices to groups.
    Posted Jan 16, 2018 09:26 AM
    So, I decided to reinstall Airwave cause there wasn't important configuration. Now everything is working well.
