Network Management
Airwave E mail alert
  • 1.  Airwave E mail alert
    Posted May 03, 2016 04:45 PM
    Hello
    im setting up an airwave in a secure network in which everything pass through an firewall.
    I have set up airwave before but in places that they didnt have internal firewalls.   In those the email alert work just fine.
    But here the email alert is not working which i supppose that it does not have access to their mail server to send the email?
    What ports do i need to make the email alert to work? its a microsoft  exchange  just port 25? to that exchange server???
    I will like to use the embebed mail server of the airwave.
    Cheers
    Carlos
  • 2.  RE: Airwave E mail alert
    Posted Jun 28, 2016 06:50 PM
    1. From Amp Setup -> Additional AMP Services -> Use Embedded Mail Server -> yes.  It enables the embedded mail server that is included with AMP.
    2. Also to configure a relay host, SSH into the AMP using SecureCRT or Putty and follow the steps below:
    1. Add the following line to /etc/postfix/main.cf:
    relayhost = [mail.airwave.com]
    where [mail.airwave.com] is the IP address or hostname of your smarthost If you do not surround the hostname with brackets, Postfix will forward mail to the mail server defined in the host's MX record, if any MX record exists for that host.
    2. Run:
    # service postfix stop
    # service postfix start
    3. Send a test message to an email address
    Mail -v xxx@xxx.com
    Subject: test mail
    <Ctrl-D> to end message.
    CC: <press enter>
    4. Check the mail log to ensure mail was sent
    # tail /var/log/maillog
    Sreedhar
  • 3.  RE: Airwave E mail alert
    Posted Apr 19, 2017 09:19 AM
    Hello thanks for the answer but  what ports do i need to open in firwall to this to work
    What ports i need when i use the embebed server
    What ports i need for the  use the relay server?
    Do i need just port 25 to the relay server and thats it?
  • 4.  RE: Airwave E mail alert
    Posted Apr 19, 2017 09:44 AM
    We need to open port SMTP port 25 in firewall for email to work.
    Please check below old community link which proivde troubleshooting steps and list of ports used by Airwave
    http://community.arubanetworks.com/t5/Aruba-Apps/Cannot-send-test-email-in-Airwave/m-p/288996#M739
    http://community.arubanetworks.com/t5/Network-Management/AirWave-Firewall-Access/td-p/148208
    Pavan
  • 5.  RE: Airwave E mail alert
    Posted Nov 16, 2017 10:16 AM
    Thank you, these instructions worked perfectly.
