Every few seconds this error shows up in our airwave syslog:
ttyS0: tcgetattr: Input/output error
We're on v 8.2.5.1. Any help would be greatly appreciated.
Thank you!
-Mike
In 8.2.5, serial port was enabled by default. Is your AMP running on a VM or hardware that doesn't have a serial port? If so, then these errors can be ignored.
Thanks for the reply. Correct, it's on a vm without a serial port. Is there a way to prevent these errors from sending out syslog messages, rather than having to set up a filter to ignore them on our syslog server?
Mike
You'll have to open a support case. Support can open the support shell and perform the changes to disable. Also, you can mention the defect DE30738 to get it up-prioritized so you don't have to redo this change in the future.
OK, thank you very much for the quick replies!
