Network Management
Airwave Event-id documentation
  • 1.  Airwave Event-id documentation
    Posted Apr 16, 2012 03:39 AM
    I am new to airwave and trying to integrate Airewave logs with Arcsight SIEM solution, Since airwave is not supported by arcsight I am going to develop custom connector.
    I searched for error/event description documentation with event-id list and types about airwave log's to build the syslog parser, however couldn't able to locate one.
    If anyone have such information or documentation please share.
    Nag
  • 2.  RE: Airwave Event-id documentation
    Posted Apr 18, 2012 06:21 PM
    I don't believe we have any documentation of our syslog contents beyond what's in the user guide.
    For what it's worth, there's a sample ArcSight connector config that can be used for handling snmp traps about rogue APs which are sent from AirWave to ArcSight.  That file is at:.
    /usr/local/airwave/bin/arcsight_flex_connector_config.txt
