Network Management
AirWave Firewall Access
  • 1.  AirWave Firewall Access
    Posted Mar 12, 2014 01:33 PM
    Can anyone point me to what ports and services are needed between Aruba controllers and AirWave? I can find documentation between controllers etc but not AirWave
  • 2.  RE: AirWave Firewall Access
    Posted Mar 12, 2014 02:24 PM
    udp 161/162 for snmp, tcp 18192 for amon
  • 3.  RE: AirWave Firewall Access
    Posted Mar 12, 2014 05:06 PM
    Amon is UDP 8211,  Syslog is also sent to Airwave on UDP 514
    Airwave also needs to SSH into the controller on port 22.
    Please see the list for Aruba devices here:  http://www.arubanetworks.com/techdocs/ArubaOS_63_Web_Help/Web_Help_Index.htm#ArubaFrameStyles/Firewall_Port_Info/Communication_Between__D.htm
  • 4.  RE: AirWave Firewall Access
    Posted Mar 12, 2014 07:19 PM
    You will find this info under the Home/Documentation tab in the AirWave web console.
    Installation guide / Configuring and Mapping Port Usage for AMP
  • 5.  RE: AirWave Firewall Access
    Posted Dec 15, 2014 09:27 AM
    Also, Airwave has the ability of downloading an upgrade image directly as part of an upgrade process with the command:
    start_amp_upgrade -v
    Does anybody know which URL, protocols and ports are used for the connection and download?
    Kind regards,
    Giuseppe Damiano
  • 6.  RE: AirWave Firewall Access
    Posted Dec 15, 2014 10:09 AM
    Here are the complete list of ports need to keep open for Airwave.
    Hope it will help you.
  • 7.  RE: AirWave Firewall Access
    Posted Dec 15, 2014 10:17 AM
    Thank you Venu,
    Unfortunately, that is not the answer I was looking for. The list does not show any particular URL userd by the AMP server when downloading an upgrade image nor does it state which proocol or ports are used during the online upgrade.
    Hopefully, somebody will post with the answer soon.
    Giuseppe/
  • 8.  RE: AirWave Firewall Access
    Posted Dec 15, 2014 10:51 AM
    Hi Friend,
    It uses HTTPS and will contact and download the updates from support.arubanetworks.com
    Hope you got your answer :)
    Please feelfree for any further help on this.
  • 9.  RE: AirWave Firewall Access
    Posted Dec 15, 2014 11:00 AM
    Hi friend,
    More precisely it uses the following links for auto, mannual and old download methods.
     manual_download_url => 'https://support.arubanetworks.com',
    old_download_url => 'http://www.airwave.com/download
    Hope answered your query completely, if not please feel free to come back :)
