Airwave Firewall reports?
  • 1.  Airwave Firewall reports?
    Posted Oct 09, 2013 09:10 AM
    Hey Everyone,
    Forgive me but I cannot see any reports based on the new Firewall section of AMP 7.7.4.
    Is there any report that I can run canned or custom that can give me some data in report form?
    Looking for anything....at this point
  • 2.  RE: Airwave Firewall reports?
    Posted Oct 09, 2013 09:39 AM
    pmonardo, there is nothing canned at the moment based upon the visability that is ported from the Controllers to Airwave, nor do the variables exist to built it custom. That said, this would be excellent functionality. Suggest you drop it in the ideas portal and I'll follow up with PLM to ascertain if this is road mapped in the upcoming release.
  • 3.  RE: Airwave Firewall reports?
    Posted Oct 09, 2013 09:48 AM
    done and done. Filed away, i'll pm you
  • 4.  RE: Airwave Firewall reports?
    Posted Oct 09, 2013 03:37 PM
    Confirmed with PLM that this is scheduled for inclusion in the forthcoming release if AirWave.
    Cheers, Adam
