Network Management
Airwave flow consumption
  • 1.  Airwave flow consumption
    Posted Jul 15, 2018 09:20 AM
    Hello ,
    I would like to inquire about the possibility of adding a second site on my airwave.
    The two site  are connected through vpn  a link of 2M. How could I estimate the flow consumption ?
    what to check before adding the equipment of the second site (access points and controller)?
    Thanking you in advance.
  • 2.  RE: Airwave flow consumption
    Posted Jul 16, 2018 10:12 AM
    You could try taking a tcpdump of traffic to and from the AMP for an hour of time.  This would give you a good idea of the level of traffic that you get in an hour.  If you're only using SNMP, you could limit to port 161.  If you're doing AMON, you'll have to include port 22 and 8211.
    Be sure to attempt a poll now during the capture window from your controller/switches to ensure it's accounting for the data polling activity.
