Wired Intelligent Edge
last person joined: 8 hours ago
Airwave - How to add a stack of 2920 switches
  • 1.  Airwave - How to add a stack of 2920 switches
    Posted Dec 28, 2017 12:16 PM
    Hi all,
    Have some spare Airwave licences so was trying out Airwave management/monitoring of 2920s running the latest Aruba-branded firmware.  Works well!
    Now, in production we have stacks, not individual switches and this is where by problems start.  With the individual switches I was manually adding them in Airwave and it was detecting the correct template for the switch.  With the stacks I just can't get it to detect anything and I don't know how to manually map atemplate to a device.
    I just get a device added that is always down and config is never collected.
    Any tips or suggestions please?
    Thanks a lot.
    Toby
    PS: Airwave 8.2.3.1 - HPE_ArubaOS on switches WB.16.04.0008
  • 2.  RE: Airwave - How to add a stack of 2920 switches
    Posted Dec 28, 2017 02:34 PM
    Hi Toby,
    This should be simular as adding a normal switch. Aruba has optimed switch management in the latest AirWave firmwares. I will advise to upgrade AirWave to the latest firmware (8.2.5.1).
    Are you sure SNMP configured correctly (and allowed in the firewall(s)? Normally a device should up if ping is allowed and also if the device type is unknown. I think the traffic is not allowed from AirWave to the switches.
    Willem
  • 3.  RE: Airwave - How to add a stack of 2920 switches
    Posted Dec 29, 2017 04:43 AM
    Thanks Willem.
    Having looked into it deeper it does appear to be an issue with traffic between AirWave and the switch stack - rather than a problem with AirWave or my process.
