Airwave - How to remove Mismatch column header(s)
  • 1.  Airwave - How to remove Mismatch column header(s)
    Posted Sep 08, 2015 12:00 PM
    Airwave 8.0.7 - APs/Devices>List (how can I remove Mismatched from the header column? and also need to remove the Configuration header column (if possible)
  • 2.  RE: Airwave - How to remove Mismatch column header(s)
    Posted Sep 08, 2015 12:08 PM
    AMP setup > General > Top Header > Stats
  • 3.  RE: Airwave - How to remove Mismatch column header(s)
    Posted Sep 08, 2015 12:15 PM
    I dont have it selected there.  I dont see it on the main header section
    please see attached
  • 4.  RE: Airwave - How to remove Mismatch column header(s)
    Posted Sep 08, 2015 12:19 PM
    That first one can't be removed AFAIK.
    To remove it from the list, you need to clone the default view and remove the column.
  • 5.  RE: Airwave - How to remove Mismatch column header(s)
    Posted Sep 08, 2015 12:21 PM
    Maybe I can do something else.  I am trying to remove any devices as coming up as Mismatched.  Its not a feature we currently use in our environment.  I turned off all auditing but still see many devices is a mismatch config state.  So my next thought was to just remove the column.
  • 6.  RE: Airwave - How to remove Mismatch column header(s)
    Posted Sep 08, 2015 12:36 PM
    Most folks just ignore it.
    The only way to truly get rid of it would be to import the config to the group when you make a change.
    Tim
  • 7.  RE: Airwave - How to remove Mismatch column header(s)
    Posted Sep 08, 2015 12:38 PM
    I dont need to truly get rid of it.  Just dont want to see that configuration column because it is irrevelant in my situation.
  • 8.  RE: Airwave - How to remove Mismatch column header(s)
    Posted Sep 08, 2015 12:39 PM
    You can just remove the column from the view then.
    Tim
  • 9.  RE: Airwave - How to remove Mismatch column header(s)
    Posted Sep 08, 2015 02:10 PM
    how do I go about doing that?
  • 10.  RE: Airwave - How to remove Mismatch column header(s)
    Posted Sep 08, 2015 03:06 PM
