Airwave, IAP's and mismatches
  • 1.  Airwave, IAP's and mismatches
    Posted Jan 11, 2014 04:28 AM
    Hi All,
    Running Airwave 7.7.7 with IAP-105's running fw4.0.0.2
    I have been struggling to get rid of the "mismatches". Basically the VC reports itself as Good but the two AP's are "mismatched" according to Airwave. When I look at reason I see the below.
    What puzzles me is that this does not seem to be something I control via the template? So its almost like the VC is sending its "own" stuff to the AP's.
    Anyone seen this before ?
    Template:
            per-ap-settings 9c:1c:12:c9:08:69
              a-channel 36 0
    Actual    a-external-antenna 0
    Desired   a-external-antenna
              g-channel 1 0
    Actual    g-external-antenna 0
    Desired   g-external-antenna
              hostname Dance-Floor
    Actual    ip-address 0.0.0.0 0.0.0.0 0.0.0.0 0.0.0.0 ""
    Actual    swarm-mode cluster
    Actual    uplink-vlan 0
    Desired   ip-address ""
    Desired   swarm-mode
    Desired   uplink-vlan
              wifi0-mode access
              wifi1-mode access
    Serge
  • 2.  RE: Airwave, IAP's and mismatches
  • 3.  RE: Airwave, IAP's and mismatches
    Posted Jan 11, 2014 12:09 PM
    Thanks, that seems to have resolved it.
    Serge
  • 4.  RE: Airwave, IAP's and mismatches
    Posted Jan 12, 2014 12:56 PM
    For purposes of answering here...once you import the config in the group, you need to go to all APs or an individual one and click "Import Settings" under the Manage tab.
