last person joined: 11 hours ago
Airwave ICG - facebook integration
  • 1.  Airwave ICG - facebook integration
    Posted Mar 27, 2018 03:01 AM
    hi fellows,
    am i blind or is there really something missing?
    With standalone Instant IAP installation, if i enable facebook authentication, new link appears to configure binding with facebook. all is fine.
    under Airwave management (instant gui settings for the group) there isn't such a link and there isn't anything in the ICG tree elsewhere. I can pick facebook as authentication method (under group->instant config->networks->SSID->security, but no additional settings are enabled (even after applying everything and syncing config).
    AW is 8.2.5 and IAP FW is 6.5.4.3 (policy version 5.4.3)
