Network Management
Airwave IGC - Multiple countries in same Group
  • 1.  Airwave IGC - Multiple countries in same Group
    Posted May 14, 2020 06:00 PM
    Hi all,
    I'm working on a mutli national Instant rollout and am trying to workout if i can run the all the sites as a single instant GUI config group with per VC overrides on the country code.
    The issue i see is that the group can only have a single regulatory domain configured and i'm wondering if this has any impact on instant GUI config or if this can be ignored?
    Scott
  • 2.  RE: Airwave IGC - Multiple countries in same Group
    Posted May 15, 2020 06:46 AM
    It is better to have individual group for each country code, channel bandwidht, power level & frequencies varies for each country code IAPs.
  • 3.  RE: Airwave IGC - Multiple countries in same Group
    Posted May 18, 2020 04:46 PM
    does this really apply when using instant gui configuration though? i note you can have an override at each VC level for different country code.
  • 4.  RE: Airwave IGC - Multiple countries in same Group
    Posted May 19, 2020 04:43 AM
    We can push config to individual VC from instant config but it is good to have different different group for each country it is easy to manage and also helps in Airwave reporting and trigger.
