Network Management
Airwave Install - no usable disks found
  • 1.  Airwave Install - no usable disks found
    Posted Jun 01, 2015 10:25 AM
    Trying to install Airwave onto a new Dell server and keep getting the error 'no usable disk found'
    Could be mistaken be it looks like it can't recognise the Raid controller (perc h730) and/or doesn't have the drivers.
    Any advice how to proceed?
  • 2.  RE: Airwave Install - no usable disks found
    Posted Jun 01, 2015 10:27 AM
    Did you provision the disks in the RAID configuration pre-boot?
  • 3.  RE: Airwave Install - no usable disks found
    Posted Jun 01, 2015 10:30 AM
    yes, did that.
  • 4.  RE: Airwave Install - no usable disks found
    Posted Jun 01, 2015 10:56 AM
    You may need to interrupt the installer to allow for 3rd party drivers to account for that particular RAID card.  Try opening a support case if that doesn't work.
  • 5.  RE: Airwave Install - no usable disks found
    Posted Jun 01, 2015 12:07 PM
    How do I do that and install these drivers?
  • 6.  RE: Airwave Install - no usable disks found
    Posted Jun 01, 2015 05:02 PM
    At the ISO install prompt, you can try:
    # install dd
    This should work, but I've not had to run through the 3rd party install in a long time.
    It should prompt for 3rd party driver install before going into the regular OS install.
  • 7.  RE: Airwave Install - no usable disks found
    Posted Jun 02, 2015 10:56 AM
    couldn't manage to get that to work.  TAC advised to put a base Centos 6.5 install on and follow these instructions.
    https://arubanetworkskb.secure.force.com/pkb/articles/HowTo/Install-AirWave-8-0-on-RedHat-RHEL
    All done and looking good.
  • 8.  RE: Airwave Install - no usable disks found
    Posted Jun 10, 2015 10:56 AM
    did you boot from the life cycle controller first then install airwave after?
