Getting ready for the install of the system, do you all recommend CentOS or can it be installed on windows 2008 R2?
Jeff
If found the CentOS install *completely* painless. So I'd suggest going for that.
The install CD comes with CentOS. AirWave is only installable on top of a Unix OS, of which only RedHat and CentOS are supported by support. You can get the full details from the QuickStart Guide:http://support.arubanetworks.com/DOCUMENTATION/tabid/77/DMXModule/512/Command/Core_Download/Default.aspx?EntryId=8055
