Network Management
last person joined: 8 hours ago
Airwave issue monitoring 1 Cisco 3750E switch but not another?
  • 1.  Airwave issue monitoring 1 Cisco 3750E switch but not another?
    Posted Dec 03, 2014 04:04 PM
    Hi guys,
    I have a network where 2 Cisco switches (not stacked). They are behind a firewall and the only way to get to them is to SSH into the firewall and then telnet into the switch.
    The only outside port that is open to the switches is SNMP using PAT.
    60161 -> 161 Switch 1
    60162 -> 161 switch 2
    On Airwave, I add a new device (Cisco Catalyst Switch), put in the right public IP (Static), SNMP port, etc... Switch 1 gets monitored just fine.
    Switch 2 fails on SNMP.
    1. They both have the snmp com string.
    2. Airwave (from CLI) can snmpwalk the 2nd switch just fine.
    3. Switch 2 settings are exactly the same as Switch 1 except the SNMP port is 60162 vs 60161.
    Which logs can I look at in Airwave to find out why it is failing? If any...
  • 2.  RE: Airwave issue monitoring 1 Cisco 3750E switch but not another?
    Posted Dec 03, 2014 07:48 PM
    Pmonardo,
    Once you mentioned NAT, you are on your own ;)
  • 3.  RE: Airwave issue monitoring 1 Cisco 3750E switch but not another?
    Posted Dec 04, 2014 08:31 AM
    boo ;) but you are right..
    I'll try and figure it out, it's just odd. Airwave can walk it.
    Thanks Colin but still boo. ;)
  • 4.  RE: Airwave issue monitoring 1 Cisco 3750E switch but not another?
    Posted Dec 04, 2014 12:27 PM
    Is that port differentiation mirrored on the switch manage pages?
  • 5.  RE: Airwave issue monitoring 1 Cisco 3750E switch but not another?
    Posted Dec 04, 2014 12:37 PM
    yup, the ports are different on the manage pages.
  • 6.  RE: Airwave issue monitoring 1 Cisco 3750E switch but not another?
    Posted Dec 04, 2014 03:27 PM
    Probably time to open a TAC case.
    I also suggest taking TCPdumps from the AirWave server and from the switch to see the requests inbound and outbound.
  • 7.  RE: Airwave issue monitoring 1 Cisco 3750E switch but not another?
    Posted Dec 05, 2014 09:19 AM
    Yeah, i have been doing that.
    The switch that cannot be walked is connected to the primary switch on a trunk port.
    I need to figure out how this person deployed the network first to make sure the walk can function correctly.
