Network Management
Airwave keep up without log off.
  • 1.  Airwave keep up without log off.
    Posted Nov 07, 2014 12:11 PM
    Hi All.
    I need to deploy the Airwave without logout time, because I´ll use it to monitor the APs and users in real time.
    I saw that it is possible to set a max connection time on Airwave, but it's not possible to configure it to keep up all the time.
    In the end of the max time configured, the Airwave do logoff and I need to do login all the time that it happens.
    How can I solve this problem?
    Thank you.
    Leandro Surcin
  • 2.  RE: Airwave keep up without log off.
    Posted Nov 07, 2014 01:12 PM
    Try this:
  • 3.  RE: Airwave keep up without log off.
    Posted Nov 07, 2014 01:14 PM
    This is enabled by default on the Admin role but if you are using othe roles you need to enable it:
