Yes, you can use the License Management feature in
Aruba Support portal to move your license from your one Airwave, to another Airwave installation.
Reach out to Aruba support if you get stuck during the process.
Original Message:
Sent: Nov 11, 2021 10:23 AM
Subject: Airwave licenses
Dears,
can i do migration for airwave license from VM on premise to a VM in azure cloud ?
Elhosieny Mohamed
